POWERGLIDE TO A DANA 300
Postby Mallow415 » Sat Feb 04, 2012 10:05 am
Well i got a project that im putting together for my wife! Its a cj5 and it is set up with a small block chev and has a t4 with dana 300 case. I was wanting to put a auto in it i know they make a turbo 350 conv. but i was thinking of putting a powerglide to it? Will it work and whats involved i have lots of powerglide stuff does it need to be a shorty or what?
Mallow415
Re: POWERGLIDE TO A DANA 300
Postby JustaJeepII » Sat Feb 04, 2012 11:12 am
Yeah, they're out there. Here's one option.
http://www.polyperformance.com/shop/GM- ... 20628.html
If you end up with an auto in the Jeep, might the t4 be for sale? ;)
Ability is what you're capable of doing, Motivation determines what you do, Attitude determines how well you do it.
JustaJeepII
Postby Mallow415 » Sat Feb 04, 2012 12:37 pm
Thanks Mike! Ill have to see what comes about got alot of stuff to do to it????? Not including my other projects!
Mallow415
Postby AFRd_CJ5 » Sun Feb 05, 2012 6:51 am
What's the rest of the combo? I'm probably against the grain here, but is there any reason you want to use a powerglide and not a th350?
AFRd_CJ5
Postby Mallow415 » Sun Feb 05, 2012 9:46 am
I just have a bunch of powerglide stuff and if i ever wanted my wife to race it I could put a brake in it? Just a thought?
Mallow415
Postby AFRd_CJ5 » Sun Feb 05, 2012 6:37 pm
Just wondered. I've always been told you needed x amount of HP with x amount of weight to make the powerglide work effectively. And if it sees any other use (street duty/etc.), the impression I've always gotten was that glides suck for that stuff (low speed driving that is).
I stick with a 3 speed for that reason alone. I street drive a lot, dune it, drag it. Not sure a powerglide would work in my application.
AFRd_CJ5
Postby shinn chassis » Mon Feb 06, 2012 7:39 pm
Jeff Richardson has one in his jeep up here that he drives on the street and trail rides it. He made the stuff to run it himself and I think he likes it.
shinn chassis
Postby JMF350 » Tue Feb 07, 2012 12:07 am
Don't quote me on this, but I think Jeff took his glide out after he exploded it, and went to a th350. Alot lower gear ratio for stop signs, and low speed stuff in the woods. You can put a brake in the 350 also.
Nitorus is like a sl#t.... you wanna hit it but you're afraid of the consequences.
JMF350
Postby AFRd_CJ5 » Tue Feb 07, 2012 6:52 am
JMF350 wrote:Don't quote me on this, but I think Jeff took his glide out after he exploded it, and went to a th350. Alot lower gear ratio for stop signs, and low speed stuff in the woods. You can put a brake in the 350 also.
This is basically what I've always heard. Glides suck bad for stop and go stuff (for obvious reasons). Down the road 55MPH stuff was fine because you're still at the same final ratio, but low speed driving was not good. I'd be interested in hearing if he liked it though. I would have thought trail riding with a glide would be a nightmare.
AFRd_CJ5
Postby Mallow415 » Tue Feb 07, 2012 6:13 pm
I know that a 350 might be the better choice just looking for options? Thanks Guys!
Mallow415
