wheelie bars
wheelie bars
Postby nocents572 » Mon Mar 05, 2012 11:17 am
I've been giving some thought to changing from the old two tire street style wheelie bar that I have now to a single tire set up that a lot of people are running now. Anyone have any input, positive or negative? Any help would be appreciated.
Scott
"Life's tuff....It's even tougher if you're stupid" John Wayne
nocents572
Re: wheelie bars
Postby THE BOSS » Mon Mar 05, 2012 12:08 pm
yea, i do, don't listen to Bad Company :D
Re: wheelie bars
Postby bad company » Mon Mar 05, 2012 5:08 pm
THE BOSS wrote:yea, i do, don't listen to Bad Company :D
:shock:...What?....
bad company
Re: wheelie bars
Postby adrenalinerush » Mon Mar 05, 2012 5:44 pm
Scott, I've always thought you guys could use a heavier bar. I say go for it, you guys need something that will handle the weight if you need to lean on it. I'm lucky my old heap only needs a wheelie bar if I crank the floor jack up too high in the front :D
adrenalinerush
Re: wheelie bars
Postby THE BOSS » Mon Mar 05, 2012 6:04 pm
i rest my case!
Re: wheelie bars
Postby THE BOSS » Mon Mar 05, 2012 6:51 pm
all funnen aside, we built this sub frame (stole the idea) so you didn't have to lay under the car to put it on:
most build one like this, kinda standard to the industry, this one is 1-1/4" thick wall molly, it is laying upside down:
i adjust mine closer to the ground closer than most do, around 3" off the ground on a level surface.
Re: wheelie bars
Postby nocents572 » Mon Mar 05, 2012 7:24 pm
Thanks for the help and the pics Tony!
Jason, I am changing the front end from a Dana 44 to a 30 and I'm pretty sure with the weight loss it will come up a lot harder! I think I'm gonna go ahead with the change. Thanks again!
nocents572
Re: wheelie bars
Postby THE BOSS » Mon Mar 05, 2012 7:31 pm
no problem, you can save $$$ buy all the ends at McMasters, everything except the tubing
Re: wheelie bars
Postby bad company » Mon Mar 05, 2012 8:47 pm
bad company
