Front driveshaft dia. question......
Postby Hot Stuff » Tue Apr 24, 2012 8:13 pm
How small of a diameter do you think I could get away with for my front driveshaft? Im really tight between the shaft and trans pan, and am going to notch the pan for more clearance, but since I need to make new driveshaft's, I was wondering how small of a diameter I could safely get away with. Just looking for some suggestions. Thanks
Hot Stuff
Re: Front driveshaft dia. question......
Postby sandguy356 » Tue Apr 24, 2012 8:18 pm
My red bronco had a 1 1/4" piece of solid made into a driveshaft in that.
Mud racers
90% talk 10% actual racing
sandguy356
Postby supertoy » Tue Apr 24, 2012 8:31 pm
The 1.25" od shaft should work fine, just make sure to use at least .188" wall thickness (stock jeep is only .083" or .120"). If you have room, some of our driveshaft shops use I think it is a 1.375" with .312" wall thickness. Sometimes modifying the turbo 350 pan is really the only real option depending how much up travel the bumpstops will allow.
supertoy
Postby Hot Stuff » Tue Apr 24, 2012 8:35 pm
Jeesh, that had to weigh a ton. Let me re phrase the question, how small of a diameter tube do you think I could get away with? I'm running 1.75" tube now, And the length is about 27" center to center. The new length will be about 38.5" center to center.
Hot Stuff
Postby Hot Stuff » Tue Apr 24, 2012 8:38 pm
Ya, I have to limit up travel. My biggest concern is tube diameter and wall thickness.
Hot Stuff
Postby grey ghost » Wed Apr 25, 2012 3:45 pm
Adam, I have 3/4 or 1" steel shaft on the first section on my front drive shaft going through bearing blocks, if this helps
( never could spell ) lol
BLUE OVAL GANG FOR LIFE</br>
grey ghost
Postby supertoy » Wed Apr 25, 2012 4:09 pm
The 1.25" shaft should have no problem at the 38.5" kind of length.
supertoy
Postby Hot Stuff » Wed Apr 25, 2012 4:25 pm
Ya, I have 1.25" O.D, .75" I.D. seamless DOM in stock. Its nice working at a fab shop!
Hot Stuff
Postby Dreher Race cars » Wed Apr 25, 2012 5:02 pm
grey ghost wrote:Adam, I have 3/4 or 1" steel shaft on the first section on my front drive shaft going through bearing blocks, if this helps
Don't trust this you will surely have more HP than the ghost :lol: :lol:
Postby Hot Stuff » Wed Apr 25, 2012 5:41 pm
Haha, Idk my little engine isn't anything special.
Hot Stuff
Users browsing this forum: No registered users and 3 guests
