Tire question
Re: Tire question
Postby Mikey1985 » Tue Jan 20, 2015 5:34 pm
k.Schafer wrote:That would be a good choice. Multipurpose tire wise. A suggestion I would make is check out skyjacker Soft ride springs. They ride great in my truck.
do you ride the sand dunes also?
Mikey1985
Re: Tire question
Postby k.Schafer » Tue Jan 20, 2015 6:03 pm
Yes I do. Been taking my 86 to silver lake for many years. I've missed a few also. I also used 33" boggers on the front besides the desert tracks.
k.Schafer
Re: Tire question
Postby Mikey1985 » Tue Jan 20, 2015 6:18 pm
Sweet.. i seen people like the ez ride tuff country also could save me a few hundred going with over counter springs.
Mikey1985
Re: Tire question
Postby k.Schafer » Tue Jan 20, 2015 7:20 pm
It's probably cheaper with over counter considering you can get everything in a package. I would recommend going with an all spring set up. Just my opinion.
k.Schafer
Re: Tire question
Postby Mikey1985 » Thu Jan 22, 2015 11:35 am
yea i had a 3" block on the rear from the owner before that i removed already. For sure all spring Alcan from colorado have good prices on custom springs. What shocks are you running?
Mikey1985
Re: Tire question
Postby k.Schafer » Thu Jan 22, 2015 7:44 pm
I'm running skyjacker shocks that came in the kit.
k.Schafer
Re: Tire question
Postby Straight Shooter » Fri Feb 06, 2015 11:22 pm
I would not run Scat Trak paddles on a rig like this. I don't like Skat Traks in this application for a couple reasons. Drag slick casings have super thin sidewalls and the tread face is buffed so thin they puncture real easy and the cups are prone to breaking up and coming off with low tire pressure. If you were strictly racing then the Skat's would be fine. I use on Skat Trak for my sand drag needs but for the dunes play I prefer Sand Tire Unlimited tires.
A nice set of tall cut STU 20.00's would be just right on the 15x15 wheel. Anything smaller than 20.00's and you will go just as good with a set of 12.50x33 BFG Radial Mud Terrain type tires.
Best pass during 2015 races 3.092@104.4mph at Albany OR. All motor single 4 on race gas.
Straight Shooter
Previous
