Clutch & Disc advice
Postby jhenderson » Mon Mar 16, 2015 12:26 pm
Running a 1980 CJ5 with a SBC (maybe 400hp) and T-176/Dana 300. WHat clutch/disc would everyone recommend???
Must be 11" cluth based on Flywheel
Clutch Style????
Roller Assist?????
Disc Material?????
Disc Size???
jhenderson
Re: Clutch & Disc advice
Postby sixpak » Mon Mar 16, 2015 2:42 pm
When I ran a T-10 we would set up the pressure plate without roller assist and about 2700lb. I ran nothing but a good standard disc material in the disc itself.
sixpak
Postby jhenderson » Tue Mar 17, 2015 12:43 pm
John,
Why no roller assist?
jhenderson
Postby sixpak » Tue Mar 17, 2015 3:19 pm
We found that it made it diffcult to shift at higher RPMs.
sixpak
Postby Straight Shooter » Mon Mar 23, 2015 10:49 pm
For Sand drags the McLoud 10.5" 4 puck bronze disk under a 11" Ford Long style adjustable pressure plate was the ultimate. We got by with around 800-1000 pounds pressure on the disk. No heavier than a 30 pound steel flywheel. High range 1st to 2nd 2.32 to 1.69 second using 5:57 rear gear. With a 2.78 first to 1.69 2nd we use a 5.38 rear gear. Either was perfect for 400 to 500 horses running 5.5's to 4.5's for ET's. Our weight were from 3200 to 2500 pounds using these ratio's. When I ran a Muncie it was with the 5:38's and it worked very well but became a little fragile as the power increased. The Ford Top Loader is the ultimate and now that Liberty has gone from the Liberty pro shifted style to face tooth engagement is it super fast and super durable.
For mud bogs we used the exact same setup but in 4 low using 3 and 4rth for the over the tire really deep mud. Best way to wreck a clutch was to grease it up in deep mud and slip it real bad. The trick there was get the right gear and no shifting.
Best pass during 2015 races 3.092@104.4mph at Albany OR. All motor single 4 on race gas.
Straight Shooter
