Front Halfing the Altered
Re: Front Halfing the Altered
Postby sandaltered » Sun Feb 05, 2012 5:37 pm
Got a couple hours in yesterday to get the engine in and hopefully centered up. Got a few framerails mocked up. They still need a small bend in each one and cut to length.
Postby JonJ » Mon Feb 06, 2012 5:58 pm
Looks good Mike, ever think of a slingshot dragster? You got a good start!! ;)
JonJ
Postby sandaltered » Sat Feb 25, 2012 4:35 pm
I've been travelling so I haven't touched this in about two week. Put in a decent day today and got all the uprights and cross members tacked in.
I got some better pics I'll post later. Let's just say, she's skinny.
Postby sandaltered » Sun Feb 26, 2012 8:40 am
This tube used to be about 13" wide. It's now 8.
Postby adrenalinerush » Sun Feb 26, 2012 8:50 am
Looks good Mike. Why the change to narrow it up?
adrenalinerush
Postby sandaltered » Sun Feb 26, 2012 10:02 am
That's just kinda how it ended up after bending, even though I pretty much matched the old bends perfectly. I kinda liked it, so I'm going to give it a try. I'm going to have to change the layout of things in the front, like the fuel cell. But I wanted to clean up the front anyway. It was cluttered.
Postby sandaltered » Fri Mar 09, 2012 7:23 pm
Got a little more time in.
Postby sandaltered » Sun Apr 22, 2012 7:43 pm
It's hard to believe my last post is over a month old and I don't really have much more to show. We've been doing more family and house stuff, and I've had tons of tires to ship. So this has been slow at best.
Made some bolt on A-arms. Though if these get bent I'll probably do something different anyway. Oh well.
Then spent the better part of the past two weekends welding it all up. I'm not the best, but I've certainly seen worse:
And here's the finished project. Just a few tabs and brackets left to weld. Then some aluminum work that I've already started on.
Postby G-String » Mon Apr 23, 2012 10:18 am
Mike,
You should be VERY Proud of that RIDE!!!
I did almost the Same thing on my Last Altered,stepped the Frt.half in Real narrow,gives it a Digger look!
I went a little Longer(140"),
I Have some Casings,Big Stuff!You in NEED of ANYTHING Inparticular?SIZE Wise,.........?LMK?
Later
G 8-)
G-String
Postby Sebastian Lindau » Mon Apr 23, 2012 1:03 pm
Your weld looks very good and the whole fabrication at all. Really good job Mike!
Best regards, Sebastian.
Sebastian Lindau
