[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4760: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4762: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4763: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4764: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
Sand Drag Central • View topic - Can't wait to get started
Feel free to introduce yourself!
Postby Itsturpintime » Fri Mar 21, 2014 9:47 am
Fairly new to sand dragging. Now I am stepping it up to the big class out here in central cal. I have built a 525 bbc that I plan in running a 200 shot on so it should be right around 1000 hp. I am also building a tube chassis Nissan 4x4 truck should be around 2500-2800lb I am running a turbo 400 with a 5000 stall and I am trying to find out what gearing I should be running ? Thanks every one !
Itsturpintime
Re: Can't wait to get started
Postby bad company » Sat Mar 22, 2014 7:17 am
Most guys around use run in the 6.00:1 range without a transfer case, or in high range. Not sure what gear if you're reducing through a case
bad company
Postby Itsturpintime » Sat Mar 22, 2014 9:21 am
Thanks. Yea I'm running a t-case but just plan in running high range . Thanks agin
Itsturpintime
Postby adrenalinerush » Sun Mar 23, 2014 6:53 pm
Sounds like a cool truck...but I would put a powerglide in it. It will be faster.
adrenalinerush
Postby Itsturpintime » Sun Mar 23, 2014 7:18 pm
Yea I probably should have went with the glid and a chain drive. But I already built the 400. Thanks for the in put tho...
Itsturpintime
Postby adrenalinerush » Sun Mar 23, 2014 8:03 pm
No doubt if you have the stuff already then use it. Will probably need to gear it pretty high to make that low 1st gear work.
adrenalinerush
Postby Itsturpintime » Mon Mar 24, 2014 9:42 am
What would u suggest? Thanks
Itsturpintime
Postby Hot Stuff » Mon Mar 24, 2014 9:20 pm
Not a real good comparison, but im at 2500# with driver, a little 269" small block chevy, with a th350, with 5.38 gears in the rear, 4.88 up front. I launch at 6000 rpm in 1st, and shift into 2nd almost immediately after releasing the brake, then shift into 3rd at 8200 rpm and trap at 8200 rpm in 300'. All in high range. Seems the key to a 3 speed is getting it out of 1st gear ASAP. I have a custom planetary with a 2.23 first gear, 1.42 second, and 1:1 third. It's better than the stock 2.52, 1.52, 1:1. I like it. But if I ever redo the drivetrain setup, it'll be a glide. I only went with the th350 because I had it, and I run a tcase. No way to hook the glide to a tcase in my super short wheelbase.
Hot Stuff
Postby Dreher Race cars » Tue Mar 25, 2014 8:53 am
Postby Dreher Race cars » Tue Mar 25, 2014 9:29 am
Itsturpintime, Do you have a transbrake, if you do is it for low gear only? What rear tires and tire height do you plan on running ?
Return to New Members
