TRI-COUNTY 4X4 JULY 19 HELP SUPPORT HONOR FLIGHT
Postby RANDY JAMES » Wed Jul 02, 2014 2:55 pm
Re: TRI-COUNTY 4X4 JULY 19 HELP SUPPORT HONOR FLIGHT
Postby RANDY JAMES » Wed Jul 09, 2014 9:34 am
CONSISTANCY CLASS=ENTRY FEE $25 WITH 100%PAYBACK
MODIFIED STOCK=ENTRY FEE $25 WITH 100% PAYBACK
SUPERSTOCK=ENTRY FEE $25 WITH 100%PAYBACK
PROSTOCK=ENTRY FEE $25 WITH 100%PAYBACK
OUTLAW PROSTOCK=ENTRY FEE $25 WITH 100%PAYBACK
OPEN CLASS=ENTRY FEE $50 WITH 100% PAYBACK fast track
SPORTMAN INDEX=ENTRY FEE $25 WITH 100% PAYBACK
PRO INDEX 3.7 AND FASTER=ENTRY FEE $25 WITH 100%
Postby RANDY JAMES » Wed Jul 09, 2014 9:38 am
2014 Tri-County 4x4 Fasttrack Mud Racing Rules
1. Tech-In ends at noon. All drivers must be teched in and registered by noon or you will have to pay a late entry, a fee of double the entry. Due to past problems we will enforce this rule!!!!
3. All drivers must sign a waiver. No drivers under 18 will be allowed to race unless a parent signs a waiver, must be 16 to drive a vehicle.
4. ABSOLUTELY NO DRUNK DRIVERS!! If there are complaints about a driver being intoxicated while racing he/she will forfeit all entries and be disqualified from all races.
8. Only driver entered for a class may run in that class. You can not have someone run in your place. If you are unable to race you will be disqualified and entries will be forfeited.
9. Drivers and one crew member allowed in the pit area. ABSOLUTELY no unattended children in the pit area.
11. If needing to change tires you must let officials know during time of inspection.
12. All drivers must wear seatbelt and helmet.
13. OFFICIAL’S DECISION IS FINAL!!!! Absolutely no arguing with officials will be tolerated! If you continue to argue you will be escorted off premises.
15. Four wheel brakes, except for two wheel drive altered, rear engine dragsters, etc. with spindle mount wheels.
16. In order for a class to race there must be at least 2 drivers in that class, pay first place only!!
18. $25 per class entry fee, 100% payback (50% first, 30% second, 20% third)
19. If race starts and gets cancelled we will give tickets for gate fee, NO REFUNDS. (tickets will be good for next race date only)
20. Any vehicle running trans-brake or nitrous must have trans-shield or trans-blanket.
21. Any protest of a vehicle must be made to a race official before the class starts. The protest committee will consist of Head of Tech and Executive Committee. A fee of $25 cash will be assessed for all protests. In the event that the protested vehicle is found to be legal, the $25 will be donated to the vehicle being protested. If the vehicle is found to be illegal, the $25 will be refunded to the individual who presents the protest. Protest must come from drivers within that class only.
The Sportsman class uses an Index for the dial-in time. Each racer’s quickest qualifying ET ( out of 2 rounds in consistency class) will be used to set their Index. This will be set to the one-tenth of a second (.1) quicker than the racer’s ET. For example, a qualifying time of 4.28 would set an Index of 4.20. Entries can run no faster than 3.80 to run this class. Racers must run consistency class to get qualifying time.
The Pro class uses an Index for the dial-in time. Each racer’s quickest qualifying ET ( out of 2 rounds in consistency class) will be used to set their Index. This will be set to the one-tenth of a second (.1) quicker than the racer’s ET. For example, a qualifying time of 3.28 would set an Index of 3.20. Entries do not have to run a 3.70 in qualifying to enter the class, but must dial the maximum Index of 3.70 during eliminations. Racers must run consistency class to get qualifying time.
40 and down uncut DOT tires, must be full body. No vacuum requirements. Gutting allowed. No aluminum blocks allowed. V8 mini-trucks allowed. Must retain factory type suspension. No 4-links, no sliders, no coil-overs, etc, rearend must be welded to pring perch, minimum of 3 leaf springs. No dual carbs, nitrous or aftermarket fuel injection. Must have roll bar or roll cage attached to frame in minimum 4 points. Can have any engine, does not have to match body make.
Postby RANDY JAMES » Mon Jul 21, 2014 9:49 am
winners of july 19 race
MOD-STOCK
1 KELBY WEST
2 BRODY SCHROCK
3 CHIP KAYE
SUPER STOCK
1 DAVID MONROE
2 RANDY SAYLER
3 CHAD BILLUPS
WOMENS CONSIST.
1 EMILY INMAN O.109
2 DEE SALYER 0.209
MENS CONSIST
1 BLAKE WILSON 0.017
2 JOE MCNEIL 0.020
3 COLE HAYWARD 0.022
PRO-STOCK
1 JIMMY FULTON
2COLE HAYWARD
OPEN
1 JOE MCNEIL
2 RANDY SAYLER
3 JIMMY FULTON
SPORTMAN INDEX
1 MATT BAKER
2 JOE MCNEIL
3 DALE MONROE
Thanks to all races and everyone for your support
next race aug 9
