TRI-COUNTY4X4 RACE SEPT 13-14 ADD MONEY
Postby RANDY JAMES » Tue Sep 02, 2014 8:10 am
CONSISTANCY CLASS=ENTRY FEE $25 WITH 100%PAYBACK
MODIFIED STOCK=ENTRY FEE $25 WITH 100% PAYBACK
SUPERSTOCK=ENTRY FEE $25 WITH 100%PAYBACK
PROSTOCK=ENTRY FEE $25 WITH 100%PAYBACK
OUTLAW PROSTOCK=ENTRY FEE $25 WITH 100%PAYBACK
OPEN CLASS=ENTRY FEE $50 WITH 100% PAYBACK FAST TRACK passes
SPORTMAN INDEX=ENTRY FEE $25 WITH 100% PAYBACK ADD MONEY
PRO INDEX 3.7 AND FASTER=ENTRY FEE $25 WITH 100% ADD MONEY
KIDS CONSISTANCY CLASS=ENTRY FEE $5 WITH 100% PAYBACK
Tri-County 4x4
Monroe City,MO
Re: TRI-COUNTY4X4 RACE SEPT 13-14
Postby RANDY JAMES » Tue Sep 02, 2014 8:12 am
We will be having an Obstacle Course on SEPT 14 mens and wemans classes
v8 class=entry fee $25 with 100%payback
4 cyl and v6=entry fee $25 with 100%payback
side x side UTV's=entry fee $25 with 100%payback
must be 4 wheel drive
REGISTRATION 10:00 TO 12:00 OBSTACLE COURSE START AT 12:30
TRI-COUNTY 4X4 CLUB
MONROE CITY,MO
2014 Tri-County 4x4 Fasttrack Mud Racing Rules
1. Tech-In ends at noon. All drivers must be teched in and registered by noon or you will have to pay a late entry, a fee of double the entry. Due to past problems we will enforce this rule!!!!
3. All drivers must sign a waiver. No drivers under 18 will be allowed to race unless a parent signs a waiver, must be 16 to drive a vehicle.
4. ABSOLUTELY NO DRUNK DRIVERS!! If there are complaints about a driver being intoxicated while racing he/she will forfeit all entries and be disqualified from all races.
8. Only driver entered for a class may run in that class. You can not have someone run in your place. If you are unable to race you will be disqualified and entries will be forfeited.
9. Drivers and one crew member allowed in the pit area. ABSOLUTELY no unattended children in the pit area.
11. If needing to change tires you must let officials know during time of inspection.
12. All drivers must wear seatbelt and helmet.
13. OFFICIAL’S DECISION IS FINAL!!!! Absolutely no arguing with officials will be tolerated! If you continue to argue you will be escorted off premises.
15. Four wheel brakes, except for two wheel drive altered, rear engine dragsters, etc. with spindle mount wheels.
16. In order for a class to race there must be at least 2 drivers in that class, pay first place only!!
18. $25 per class entry fee, 100% payback (50% first, 30% second, 20% third)
19. If race starts and gets cancelled we will give tickets for gate fee, NO REFUNDS. (tickets will be good for next race date only)
20. Any vehicle running trans-brake or nitrous must have trans-shield or trans-blanket.
21. Any protest of a vehicle must be made to a race official before the class starts. The protest committee will consist of Head of Tech and Executive Committee. A fee of $25 cash will be assessed for all protests. In the event that the protested vehicle is found to be legal, the $25 will be donated to the vehicle being protested. If the vehicle is found to be illegal, the $25 will be refunded to the individual who presents the protest. Protest must come from drivers within that class only.
The Sportsman class uses an Index for the dial-in time. Each racer’s quickest qualifying ET ( out of 2 rounds in consistency class) will be used to set their Index. This will be set to the one-tenth of a second (.1) quicker than the racer’s ET. For example, a qualifying time of 4.28 would set an Index of 4.20. Entries can run no faster than 3.80 to run this class. Racers must run consistency class to get qualifying time.
The Pro class uses an Index for the dial-in time. Each racer’s quickest qualifying ET ( out of 2 rounds in consistency class) will be used to set their Index. This will be set to the one-tenth of a second (.1) quicker than the racer’s ET. For example, a qualifying time of 3.28 would set an Index of 3.20. Entries do not have to run a 3.70 in qualifying to enter the class, but must dial the maximum Index of 3.70 during eliminations. Racers must run consistency class to get qualifying time.
40 and down uncut DOT tires, must be full body. No vacuum requirements. Gutting allowed. No aluminum blocks allowed. V8 mini-trucks allowed. Must retain factory type suspension. No 4-links, no sliders, no coil-overs, etc, rearend must be welded to pring perch, minimum of 3 leaf springs. No dual carbs, nitrous or aftermarket fuel injection. Must have roll bar or roll cage attached to frame in minimum 4 points. Can have any engine, does not have to match body make.
Re: TRI-COUNTY4X4 RACE SEPT 13-14 ADD MONEY
Postby RANDY JAMES » Wed Sep 03, 2014 11:43 am
Postby RANDY JAMES » Thu Sep 11, 2014 10:57 pm
We are racing this weekend
Postby RANDY JAMES » Fri Sep 12, 2014 4:26 pm
We are going to try to run side by side if we can.Have a wash out in left shut down lane.If it dry`s out we can file the wash out in if not we will run fast track,WE WILL BE RACING
Postby RANDY JAMES » Sat Sep 13, 2014 7:55 am
We are racing today at tri-county 4x4 in Monroe City,MO
Postby RANDY JAMES » Mon Sep 15, 2014 11:10 am
Thanks to all the racers and everyone that came and supported us.I know the weather was not the best for us last week but we made work hope everyone had a good time racing.
Thanks to everyone
next races we be oct 11 and oct 25
WE WILL NOT HAVE A RACE SEPT 27
I`ll try to get winner posted later today
Postby RANDY JAMES » Tue Sep 16, 2014 7:47 am
Winner from this weekends race
Consistency class
1 DARREN HARDWICK .49
2 ANDY JAMES .96
3 JUSTIN POTTERFEILD .126
Sportsmans Index
1 STEVEN LAMBERT
2 JUSTIN POTTERFEILD
3 JIMMY FULTON
Mod-stock
1 CHIP KATE
2 SHAWN SCOTT
3 JOE REUTHER
Pro-stock
1 JIMMY FULTON
2 CHIP KAYE
3 RANDY SAYLOR
Super-stock
1 STEVEN LAMBERT
2 RANDY SAYLER
3 SHAWN SCOTT
Outlaw Pro-stock
1 JUSTIN POTTERFIELD
2 JIMMY FULTON
Open
1 JIMMY FULTON
2 RANDY SAYLOR
3 JUSTIN POTTERFIELD
KIDS CONSISTENCY
1 KIERSTAN EPPERSON
2 ABBY HAVERMIER
3 DENNIS REEVES
Postby RANDY JAMES » Tue Sep 16, 2014 8:16 am
OBSTACLE COURSE WINNERS
8 CYL CLASS
1 JORDAN FULTON
2 JIMMY RAY HARDWICK
3 JOE MCNEIL
4CYL & 6CYL CLASS
1 JOEY REUTHER
2 JEROD CROOK
3 MICHAEL POTTERFEILD
UTV CLASS
1 DARREN HARDWICK
2 JUSTIN POTTERFIELD
3 RHETT HARDWICK
