TRI-COUNTY 4X4 RACE OCT 25
Postby RANDY JAMES » Tue Oct 14, 2014 8:27 am
CONSISTANCY CLASS=ENTRY FEE $25 WITH 100%PAYBACK
MODIFIED STOCK=ENTRY FEE $25 WITH 100% PAYBACK
SUPERSTOCK=ENTRY FEE $25 WITH 100%PAYBACK WITH ADD MONEY $400
PROSTOCK=ENTRY FEE $25 WITH 100%PAYBACK
OUTLAW PROSTOCK=ENTRY FEE $25 WITH 100%PAYBACK
OPEN CLASS=ENTRY FEE $50 WITH 100% PAYBACK FAST TRACK passes
SPORTMAN INDEX=ENTRY FEE $25 WITH 100% PAYBACK WITH ADD MONEY $400
PRO INDEX 3.7 AND FASTER=ENTRY FEE $25 WITH 100% PAYBACK
Re: TRI-COUNTY 4X4 RACE OCT 25
1. Tech-In ends at noon. All drivers must be teched in and registered by noon or you will have to pay a late entry, a fee of double the entry. Due to past problems we will enforce this rule!!!!
3. All drivers must sign a waiver. No drivers under 18 will be allowed to race unless a parent signs a waiver, must be 16 to drive a vehicle.
4. ABSOLUTELY NO DRUNK DRIVERS!! If there are complaints about a driver being intoxicated while racing he/she will forfeit all entries and be disqualified from all races.
8. Only driver entered for a class may run in that class. You can not have someone run in your place. If you are unable to race you will be disqualified and entries will be forfeited.
9. Drivers and one crew member allowed in the pit area. ABSOLUTELY no unattended children in the pit area.
11. If needing to change tires you must let officials know during time of inspection.
12. All drivers must wear seatbelt and helmet.
13. OFFICIAL’S DECISION IS FINAL!!!! Absolutely no arguing with officials will be tolerated! If you continue to argue you will be escorted off premises.
15. Four wheel brakes, except for two wheel drive altered, rear engine dragsters, etc. with spindle mount wheels.
16. In order for a class to race there must be at least 2 drivers in that class, pay first place only!!
18. $25 per class entry fee, 100% payback (50% first, 30% second, 20% third)
19. If race starts and gets cancelled we will give tickets for gate fee, NO REFUNDS. (tickets will be good for next race date only)
20. Any vehicle running trans-brake or nitrous must have trans-shield or trans-blanket.
21. Any protest of a vehicle must be made to a race official before the class starts. The protest committee will consist of Head of Tech and Executive Committee. A fee of $25 cash will be assessed for all protests. In the event that the protested vehicle is found to be legal, the $25 will be donated to the vehicle being protested. If the vehicle is found to be illegal, the $25 will be refunded to the individual who presents the protest. Protest must come from drivers within that class only.
The Sportsman class uses an Index for the dial-in time. Each racer’s quickest qualifying ET ( out of 2 rounds in consistency class) will be used to set their Index. This will be set to the one-tenth of a second (.1) quicker than the racer’s ET. For example, a qualifying time of 4.28 would set an Index of 4.20. Entries can run no faster than 3.80 to run this class. Racers must run consistency class to get qualifying time.
The Pro class uses an Index for the dial-in time. Each racer’s quickest qualifying ET ( out of 2 rounds in consistency class) will be used to set their Index. This will be set to the one-tenth of a second (.1) quicker than the racer’s ET. For example, a qualifying time of 3.28 would set an Index of 3.20. Entries do not have to run a 3.70 in qualifying to enter the class, but must dial the maximum Index of 3.70 during eliminations. Racers must run consistency class to get qualifying time.
40 and down uncut DOT tires, must be full body. No vacuum requirements. Gutting allowed. No aluminum blocks allowed. V8 mini-trucks allowed. Must retain factory type suspension. No 4-links, no sliders, no coil-overs, etc, rearend must be welded to pring perch, minimum of 3 leaf springs. No dual carbs, nitrous or aftermarket fuel injection. Must have roll bar or roll cage attached to frame in minimum 4 points. Can have any engine, does not have to match body make.
Postby RANDY JAMES » Tue Oct 14, 2014 11:29 am
We have add Money for Super Stock $400 and Sportsman index $400
Postby RANDY JAMES » Tue Oct 28, 2014 7:49 am
Race winners from OCT 25 race
1 TIM WISDOM .010
2 DAVID MONROE .018
3 MATT BAKER .020
1 JOE MCNEIL
2 JIM FULTON
3 ANDY JAMES
OPEN
1 JOE MCNEIL
2JIMMY FULTON
3RANDY SAYLOR
SUPER STOCK
1 TRAVIS SHINN
2 DANIEL FOSTER
3 DAVID MONROE
OUTLAW PRO STOCK
1 MATT BAKER
2 JUSTIN POTTERFIELD
3 JIMMY FULTON
MOD STOCK
1 KELBY WEST
2 CHIP KAYE
PRO STOCK
1 JIMMY FULTON
2 DANIEL FOSTER
3 CHIP KAYE
KIDS CONSISTENCY
SORRY I LOST THE PAPER WITH TIMES
1 KAYE
2 BAKER
3 EPPERSON
Thanks to all the racers and everyone support this year
Postby RANDY JAMES » Tue Oct 28, 2014 7:51 am
1 TIM WISDOM .010
2 DAVID MONROE .018
3 MATT BAKER .020
1 JOE MCNEIL
2 JIM FULTON
3 ANDY JAMES
OPEN
1 JOE MCNEIL
2JIMMY FULTON
3RANDY SAYLOR
SUPER STOCK
1 TRAVIS SHINN
2 DANIEL FOSTER
3 DAVID MONROE
OUTLAW PRO STOCK
1 MATT BAKER
3 JIMMY FULTON
MOD STOCK
1 KELBY WEST
2 CHIP KAYE
PRO STOCK
1 JIMMY FULTON
2 DANIEL FOSTER
3 CHIP KAYE
KIDS CONSISTENCY
1 KAYE
2 BAKER
3 EPPERSON
Thanks to all the racers and everyone for your support this year
