by RANDY JAMES » Tue Feb 03, 2015 11:18 am
2015 Tri-County 4x4 Fasttrack Mud Racing Rules
Tech-In ends at noon. All drivers must be teched in and registered by noon or you will have to pay a late entry, a fee of double the entry. Due to past problems we will enforce this rule!!!!
Drivers meeting at 12:30p.m.
All drivers must sign a waiver. No drivers under 18 will be allowed to race unless a parent signs a waiver, must be 16 to drive a vehicle.
ABSOLUTELY NO DRUNK DRIVERS!! If there are complaints about a driver being intoxicated while racing he/she will forfeit all entries and be disqualified from all races.
Once a class starts no new entries or refunds allowed.
Vehicles may be entered only once per class.
Once you are called to the line you have 3 minutes to get there.
Only driver entered for a class may run in that class. You can not have someone run in your place. If you are unable to race you will be disqualified and entries will be forfeited.
Drivers and one crew member allowed in the pit area. ABSOLUTELY no unattended children in the pit area.
No hot rodding on premises.
If needing to change tires you must let officials know during time of inspection and drivers meeting.
All drivers must wear seatbelt and strapped helmet.
OFFICIAL’S DECISION IS FINAL!!!! Absolutely no arguing with officials will be tolerated! If you continue to argue you will be escorted off premises.
Fire extinguishers in every vehicle!!!!!!!!!!!!!!!
Four wheel brakes, except for two wheel drive altered, rear engine dragsters, etc. with spindle mount wheels.
In order for a class to race there must be at least 2 drivers in that class, pay first place only!!
Must wear firesuit if running nitrous or alcohol
$25 per class entry fee, 100% payback (50% first, 30% second, 20% third) Junior racers are $5
If race starts and gets cancelled we will give tickets for gate fee, NO REFUNDS. (tickets will be good for next race date only)
Any vehicle running trans-brake or nitrous must have trans-shield or trans-blanket.
Any protest of a vehicle must be made to a race official before the class starts. The protest committee will consist of Head of Tech and Executive Committee. A fee of $25 cash will be assessed for all protests. In the event that the protested vehicle is found to be legal, the $25 will be donated to the vehicle being protested. If the vehicle is found to be illegal, the $25 will be refunded to the individual who presents the protest. Protest must come from drivers within that class only.
Must have windshield or full eye protection.
No loose objects in vehicle, front or back.
The class uses an Index for the dial-in time and a sportsman tree. Each racer’s quickest qualifying ET ( out of 2 rounds in consistency class) will be used to set their Index. This will be set to the one-tenth of a second (.1) quicker than the racer’s ET. For example, a qualifying time of 4.28 would set an Index of 4.20. Racers must run consistency class to get qualifying time.
40 and down uncut DOT tires, must be full body. No vacuum requirements. Gutting allowed. No aluminum blocks allowed. V8 mini-trucks allowed. Must retain factory type suspension. No 4-links, no coil-overs, floaters and sliders are allowed, minimum of 3 leaf springs. No dual carbs, nitrous or aftermarket fuel injection. Must have minimum of 4 point roll cage attached to frame at all points. All cage structures must be designed in an attempt to protect the driver from any angle. Cage structure must be made with a minimum 1 5/8 dia. .118 wall mild steel or .083 chromoly tubing, no exhaust pipe or black iron pipe allowed. Tubing must be notched at joints, welds must be slag and porosity free, mild steel welding must be done by MIG or TIG, chromoly welding must be done by TIG. Can have any engine, does not have to match body make.
