TRI-COUNTY 4X4 2016 RACE DATES
Postby RANDY JAMES » Wed Feb 03, 2016 4:09 pm
MAY 21
JUNE 18
Re: TRI-COUNTY 4X4 2016 RACE DATES
Postby RANDY JAMES » Tue Apr 05, 2016 7:20 am
2016 Tri-County 4x4 Fasttrack Mud Racing Rules
1. Tech-In ends at noon. All drivers must be teched in and registered by noon or you will have to pay a late entry, a fee of double the entry. Due to past problems we will enforce this rule!!!!
3. All drivers must sign a waiver. No drivers under 18 will be allowed to race unless a parent signs a waiver, must be 16 to drive a vehicle.
4. ABSOLUTELY NO DRUNK DRIVERS!! If there are complaints about a driver being intoxicated while racing he/she will forfeit all entries and be disqualified from all races.
7. Once you are called to the line you have 5 minutes to get there.
8. Only driver entered for a class may run in that class. You can not have someone run in your place. If you are unable to race you will be disqualified and entries will be forfeited.
9. Drivers and one crew member allowed in the pit area. ABSOLUTELY no unattended children in the pit area.
11. If needing to change tires you must let officials know during time of inspection and drivers meeting.
12. All drivers must wear seatbelt and strapped helmet.
13. OFFICIAL’S DECISION IS FINAL!!!! Absolutely no arguing with officials will be tolerated! If you continue to argue you will be escorted off premises.
15. Four wheel brakes, except for two wheel drive altered, rear engine dragsters, etc. with spindle mount wheels.
16. In order for a class to race there must be at least 2 drivers in that class, pay first place only!!
18. $25 per class entry fee, 100% payback (50% first, 30% second, 20% third) Junior racers are $5
19. If race starts and gets cancelled we will give tickets for gate fee, NO REFUNDS. (tickets will be good for next race date only)
20. All vehicles must have a functioning neutral safety switch. Any vehicle running trans-brake or nitrous must have trans-shield or trans-blanket.
21. Any protest of a vehicle must be made to a race official before the class starts. The protest committee will consist of Head of Tech and Executive Committee. A fee of $25 cash will be assessed for all protests. In the event that the protested vehicle is found to be legal, the $25 will be donated to the vehicle being protested. If the vehicle is found to be illegal, the $25 will be refunded to the individual who presents the protest. Protest must come from drivers within that class only.
22. Must have windshield or full eye protection
24. All cage structures must be designed in an attempt to protect the driver. No cages made of exhaust pipe or black iron pipe allowed.
25. All vehicles must have a on off kill switch located on rear of vehicle, factory stock vehicles are excluded.
The class uses an Index for the dial-in time and a sportsman tree. Each racer’s quickest qualifying ET ( out of 2 rounds in consistency class) will be used to set their Index. This will be set to the one-tenth of a second (.1) quicker than the racer’s ET. For example, a qualifying time of 4.28 would set an Index of 4.20. Racers must run consistency class to get qualifying time.
STOCK
Must pull 20” vacuum at 1200 RPM’s or less. Tires must be 35” and down and DOT approved, cannot be cut. May have one modification, either aluminum intake, headers or after market carb. No other engine modifications allowed. No larger cam, stalls, or after market engine. Can have lift but no other suspension changes. Must have exhaust. Must have full body with windshield. Must have same body that came with frame from factory. No after market ignition. May have straight axle swap in frontend.
40 and down uncut DOT tires, must be full body. No vacuum requirements. Gutting allowed. No aluminum blocks allowed. V8 mini-trucks allowed. Must retain factory type suspension. No 4-links, no coil-overs, floaters and sliders are allowed, minimum of 3 leaf springs. No dual carbs, nitrous or aftermarket fuel injection. Must have minimum of 4 point roll cage attached to frame at all points. Can have any engine, does not have to match body make.
Postby RANDY JAMES » Mon May 23, 2016 7:25 am
TRI-COUNTY 4X4 MAY 21 RACE WINNERS
MODIFIED STOCK
1 BRADY JOHNSTON
2 BRIAN BELL
SUPER STOCK
1 JAMES LEWIS
2 JUSTIN POTTERFIELD
3 GOEFF BEAVER
OUTLAW PRO-STOCK
1 JIMMY FULTON 3.339
2 MATT BAKER 3.421
1 JIMMY FULTON 3.580 3.600 .020
2 TIM BENNETT 4.430 4.398 .032
3 KEITH HOOPER 5.465 5.431 .034
1 JUSTIN POTTERFIELD
2 STEVE LANVERMEIER
3 TRACY SHINN
KIDS CLASS
1 CURTIS GUPTON
2 WITTNEY SHINN
3 ABBY HAVERMALE
Thanks to every one who came out
next race June 18 th
Postby RANDY JAMES » Fri Jun 03, 2016 8:20 am
Next race june 18
Postby RANDY JAMES » Tue Jun 28, 2016 7:59 am
Winners from June 18 race
SUPER STOCK
1 JAMES LEWIS
2 IAN DIEGLEMAN
3 GRAIG FAHS
1 RHETT HARDWICK .000 PERFECT
2 TRACY SHINN .002
3 DON REIS .005
4 JOHN HOUSE .006
1 JIMMY FULTON
2 JAMES HENDERSON
3 DARREN HARDWICK
KIDS CLASS
1 CURTIS GUPTON .043
2 DYLAN MAHER .103
3 ASHLEY GUPTON .106
Thanks to all the races and everyone who came to the races and all the volunteer help
thanks
