A&S 20MM Cougar
A&S 20MM Cougar
Postby feelsoright03 » Fri Aug 03, 2012 9:38 am
Cougar PROFormance prototypes 90" chassis W/ A&S built power house! 180hp just built, ran 8 passes, spent 2300 in may.. Best time of 3.97 with 325lb rider. Will run 3.5's-3.'6's with light rider..20 mill 833cc spread bore. Billet cases, matton 10 disc clutch. Lectrons, billet 4 speed trans. Braided fuel lines, nose tank, PVL ignition, remote starter sold with the bike. Aluminum battery boxes. Bearing support, same side huge bore Shears. 18 pdl 12x12 rippers, or STUs. Or both? Mod quad heavy duty axel. Direct drive front wheels, Fiberglass Hood is not included.. Plus much much more. Call or text.
248-755-9175
$8500 for bike complete..
Part out for $6500 on motor/$2000 on chassis as roller!
feelsoright03
Return to ATV Classifieds
