parts and pieces for sale large list
Postby nitrostacker » Tue Oct 13, 2015 12:50 pm
Lots of Fuel and Alcohol Parts and Tooling For Sale:
COMPLETE Blown Top Dragster Turnkey Very Nice Car Contact for more info
TOOLING:
Piston Compression Height Tool 1 $50.00
Piston Height Tool 1 $95.00
Rod Standard 6.995 1 $40.00
Rod Standard 7.015 1 $40.00
Rod Standard 7.011 1 $40.00
Rod Standard 7.035 1 $40.00
Piston Standard 1.690 1 $30.00
Piston Standard 1.710 1 $30.00
Piston Standard 1.757 1 $30.00
Wrist Pin Standard JT 1 $60.00
8 Olsen Piston Racks 6 used 65.00 each/2 one race used 90.00 each
1 Manual Ring Grinder 40.00
1 PUSHROD RUNOUT TOOL 80.00
1 Manifold deck height dial indicator plate jt stewart 750.00
2 Larry Miersch 48 Volt Starter Battery Packs with Charger and remote switch 600.00 each
2 RCD 48V Starter Packs 500.00 Each
1 New Inferred digital track temperature gun 40.00
2 CNC Engineering 8 Stand Clutch Pack Loaders 75.00 each
3 brand new sets of engine lift bars 100.00 per set
1 Set of triple T engine lift bars 175.00
Used KB Sleeve Puller Head 1 $12.00
New Sleeve Puller Head 3 $50.00
1 Crank Gear Hub Installer 70.00
WESCO Valve Stretch Tool 1 $75.00
1 Set of Hemi Rocker Shaft Mounted Valve Spring Changing Tools 150.00
1 Set of Starting Line Tire Brushes 45.00
1 Airplane Altimeter 100.00
Clutch Spring Tester to simulate linear test for cannon 1 $250.00
3 Sets of Hartman aluminum engine cover plates 40.00 each
1 engine cradle dollies to hold spare engines on 100.00 each
MOTOR PARTS:
1 3 Run AJPE Billet New Style Nitro Block Standard Main 1 1/16 Lifter Needs minor windows on 1 & 2 and possibly saddle on #2 Main Nice Block (Rough repair cost $1000) 2800.00
Dunn dual mag drive $ 475.00
1 RCD TFX Bearing Support Front Gear Drive Cover 800.00
2 TFX Billet Blocks -.500 Deck 4.310 Bore w/Studs and Oil Pans 4,000.00 Each
JT Stewart 1.156x3.400 Nitro Wrist Pins 5 $35.00
Used JE Pin Buttons for Dome Fuel Pistons 94 $0.75
80 NEW CP Top Fuel Flat Top Pistons 4.187 Bore 1.620 CH Small Ring 60.00 Each
New JE Dome Style 4.187 Fuel Piston Big Ring 1.814 CH 46 $40.00
New JE Dome Style 4.187 Fuel Piston Big Ring 1.757 CH 2 $40.00
Used JE Dome Stye 4.187 Fuel Piston Big Ring 1.757CH 2 $20.00
Used JE Dome Stye 4.187 Fuel Piston Big Ring 1.712CH 5 $20.00
New JE Dome Style 4.187 Fuel Piston Sm Ring 1.712CH 3 $40.00
Used JE Dome Style 4.187 Fuel Piston Sm Ring 1.757CH 7 $20.00
New JE Dome Style 4.187 Fuel Piston Sm Ring 1.757CH 3 $40.00
NEW BAE/KB Hemi FelPro 1834 Hemi Oil Pan Gaskets steel insert 28.00 Each
New TFX/Rodeck Hemi FelPro 1838 Oil Pan Gaskets steel insert 28.00 each
New SCE TFX Oil Pan Gaskets 40.00 Each
New SCE Rear Main Seal Sets 29.00 Set
3 Sets of good Crane 1 1/16 wide wheel fuel lifters 350.00 a set
1 Set of good used Crane 1" Lifters 350.00 Set
New std 4.187 lightweight sleeves and oversized .040 sleeves 60.00 each or refinished by Wilkerson for 38 each
1 Good Used Honed 4.310 Bore Sleeve 40.00
4 Good Bored 4.310 Bore Sleeves 25.00 Each
1 New 4.310 Bore Sleeve 65.00
1 New RCD Titanium Bearing Support with Bearing 300.00
7 Std Hemi RCD Single Bar Idler Assemblies with Adjuster Screw Hole and Blower support Stands 285.00
9 CNC Mag Drive Support Brackets 80.00 Each
3 RCD Mag Support Brackets 50.00 Each
8 RCD Aluminum Idler Front Support Bars 65.00 Each
6 PSI Crowned Idler Pullies 165.00 each
2 Good Small Hex Oil Pump Drive Shafts PSI 45.00 Each
8 RCD Midflange Degree Rings W/magnets 100.00 Each
3 USED RCD STEEL SPLINED CRANK HUBS 75.00 EACH
1 USED RCD TITANIUM SPLINED CRANK HUB 100.00
6 Good Used PSI Bearing Support Crank Hubs Steel 75.00 Each
1 RCD Bearing Support Steel Crank Hub w threaded nut for Pulley setup 100.00
1 Good used 6 Run PSI Crank Gear Splined 50.00
2 Good Titanium RCD non bearing support keyway crank hubs 200.00 each
6 Good Steel RCD non bearing support keyway crank hubs 90.00 each
1 Good Steel RCD non bearing support splined crank hubs 150.00
7 New RCD Steel non bearing support crank hubs keyway 145.00 each
5 Good used Cassalle cam gear hubs for 7/16 shaft 75.00 each
2 Good used Cassalle cam gear hubs for 1/2 shaft 75.00 each
3 Good used Cassalle cam gear hubs for 9/16 shaft 75.00 each
4 Good Used Cassalle cam gears 75.00 each
2 TFX Billet Hemi Cam Gear Drives non bearing support 450.00 each
1 Cassale Cast Cam Gear Drives KB/BAE 350.00
2 TFX Billet 4" Fuel Pump Extensions 125.00 each
3 Good TFX Idler gears w/shaft and bearing 75.00 each
7 New CR 21771 Crank Seals 9.00 each
4 New CR 21091 Crank Seals 9.00 each
6 New SKF 638510 Crank Seals 9.00 each
9 New TKO Japan Bearing Support for Crank Replacement Roller Bearings 35.00 Each
1 Good Used Bryant 20 run 4.150 keyed hemi crankshaft w/crank gear 1500.00
3 Good Used Large Drive Std Extension Pump Driveshaft's 45.00 each
4 Billet Magneto Clamps Medlen 95.00 each
2 New Wizards Steel Magneto Band Clamps 20.00 Each
3 Good Used Fuel Pump Band Clamps Quick Disconnect 25.00 each
Various Pushrods lengths and types tell me what you need $$$$$$$
Various Grind fuel camshafts tell me what you need $$$$$$$
5 Titanium Idler Pulley Studs and back spacer 90.00
35 New A-1 Flanged 9/16 head nuts with 11/16 12 pt head 6.50 each
4 Leahy TDC Pickups 90.00 each
3 Leahy long pickups 90.00 each
4 Leahy short pickups 90.00 each
1 RCD Splined Crank Hub Non Bearing Support Good Used RCD Spline 50.00
Tons of studs/bolts/nuts used and new just tell me what you are looking for $$$$$$
JE Flat Top Pin Buttons Used 143 $0.75
Leahy Block Female Ground Plugs 7 $9.00
Fram Oil Filter Billet Wrench Set 35.00
Oil Filter Chassis Clamps Billet 20.00
Fram Oil Filter Elements 25.00 Each
Fram Oil Filter Check Spring 8.00
Fram Oil Filter Front & Rear Covers Billet 20.00
1 RCD Billet Remote Screw On Oil Filter Mount w/hardlines 100.00
14 K&N Screw on oil filters new HP5001 25.00 Each
1 Billet Aluminum RCD Crank Mounted Starter Bracket Assembly 300.00
HEAD GASKETS
All are 4.310 Bore
USED (3) .070,(2) .081 25.00 each
NEW (4) .065, (2) .075, (4) .080, (4) .071, (2) .061, (6) .044, (2).046 65.00 each
BLOWER & MANIFOLD:
2 Late model John Force Top Fuel Superchargers 5000.00 each
Used 1 Run 11mm Blower Belts $35.00
53 2 11mm mid flange crank pulley $95.00
54 2 11mm mid flange crank pulley $95.00
55 1 11mm mid flange crank pulley $95.00
56 1 11mm mid flange crank pulley $95.00
Manifold Distribution Block 1 $48.00
Used Small Burst Panels 12 $6.00
New Smal Burst Panels 20.00 Each
Used PSI Mag Case 14-71 Fuel Blower Cases 2 $300.00
1 New RCD Steel blower starter dog 90.00
12 New Cans of Prizm Blower Lube 16.00 per can
Two Billet PSI cases $ 2200.00 ea.
Billet AJ blower case , like new , 9” opening .....$ 2800.00
2 Sets of enderle manifold stainless hardlines 85.00
2 manifold distribution blocks 100.00 each
2 enderle hat distribution blocks 45.00 each
2 sets of Goodridge lightweight injector/blower hat lines nice 125.00 set
1 PSI Std Fuel Blower Rear Bearing Plate 300.00
1 Billet PSI Front Cover for Fuel Blower 300.00
3 Good Used PSI setback fuel Blower quill shafts 175.00 each
2 Psi good used drive couplers 100.00 each
8 NEW PSI CLOVER LEAF PLATES 75.00 EACH
22 USED PSI CLOVER LEAF PLATES 35.00 EACH
New Dynamic Machine blower clover leaf stainless shims .002/.003/.005/.010/.015 7.00 each
NEW Aluminum Black Anodized Std 11mm GT 35 Tooth Blower Pulley 65.00
6 NEW ARP Manifold Studs 3.980 Long 10.00
20 Good Used 3 1/4" Steel Manifold Studs 3.75 each
1 USED 1 RUN 8MM BLOWER BELT $35.00
FUEL & CLUTCH MANAGEMENT
Electrimotion Electric Pressure Regulator for BDK or Slide Complete 650.00
JT Stewart Whitey Valve For Main Jet 1 $125.00
JT Stewart Clutch Accumulator Piston for Linear 3 $40.00
JT Stewart Clutch Accumulator Cover For Linear 1 $40.00
Automan Plunger Valve 1 $30.00
Swaglock Large Flow Valve 1 $30.00
NEW Enderle Fuel Port Line Blocks 1/8 Pipe/2-10/1-6 2 $30.00
McKinney -8/-10 Y Blocks w/AFT Gold Check Valves 1 $100.00
McKinney -8/-10 Y Block 4 $60.00
McKinney -10/-10 Y Block 1 $65.00
NEW XRP 71300 -12 100 Micron Fuel Filter 1 $120.00
Fuel Filter Cartridge 1 $35.00
JT Stewart 8 1/8 Pipe Whitey Valve 1 $140.00
Waterman -8 Aluminum Check Valves 15 $45.00
AFT Gold -8 Idle Check Valves 2 $50.00
DJE -10 Check Valves 4 $45.00
NEW Keftner -6 Check Valves 4 $65.00
Assorted Enderle Main Jets 15-165 Contact for Exact Sizes and Quantity 98 $3.00
Waterman Used 1.000 Fuel Pump Gears 4 $45.00
Waterman -10 Check Valve Ported 1 $45.00
AFT Large Slide Valve Piston Brass 1 $65.00
Used Waterman Black Fuel Pump Inlets 2 $48.00
Tall CO2 Bottle with top and NOS Regulator 1 $75.00
Gold Waterman Center Bearing Plate Small Pump 1 $50.00
Waterman Fuel Shutoff Arms 2 $7.00
Waterman Fuel Shutoff Spool 1 $18.00
Small AFT Slide Valve Quad Seals New 6 $3.00
16 Stage JT Stewart Jet Style Fuel Management 1 $450.00
Rage 98 gpm pump .....$ 2200.00
2 used -20 Wiggins clamps 20.00 each
1 Good Enderle -8 Fuel Shutoff 125.00
2 New Waterman -6 Inline Check Valves Red Aluminum 65.00 Each
2 New Kepner Products Inline -6 Aluminum Check Valve Inline 65.0 Each
1 Good Used Waterman Gold Fuel Shutoff 200.00
Jt 4 valve clutch flow 175.00
2 New -24 Wiggins Clamps 25.00 each
2 New -16 Wiggins Clamps 15.00 each
1 New -12 Wiggins Clamp 10.00
2 new -10 waterman aluminum check valves 35.00
2 Good Used Air Cylinders for Saftey Shutoff System Chutes and Fuel 20.00 each
Various Lightweight fuel and oil lines available new and used tell me length and size you need $$$$$$$$$
IGNITION:
MSD 8147 Points Boxes Leahy Checked 425.00 Each
1 Brand new MSD 8173 Timing Controller 375.00
New MSD Pro Mag 44 Big Cap 7409 Wire retainer caps 20.00 each
Setup Cap 1 $10.00
Phasing Rings 45.00
8132 Coils 1 Race 5 $150.00
Magnesium Murf Ignition Plates For Dragster 3 $225.00
Used Dual Plug MSD Hemi Wires Test Good 6 $145.00
MISC Spare Wire And Plug Parts 1 $125.00
Good Used 104" Leahy Grey Cable for ignition changed every 4 races125.00 each
CYLINDER HEADS:
1 Set of good BAE Magnesium Dual Plug Hemi Valve Covers Black 800.00
1 Fresh from BAE Brad .100 tall Fuel Heads nice bare 1400.00 set
Complete AJ5 Fuel Cylinder Heads With Ti Nozzles/Ti Fuel Rails/H-11 Studs 16 $2800.00
2 Fresh Repaired AJPE Stage V Fuel Heads Look New 1000.00 Each
Used Manley Triple Springs 425 and Up 16 $12.00
New Manley Triple Spring 51 7 $20.00
Assorted Crawford Drop In Jets 1000 Contact for Exact Sizes and Quantity 1 $3.00 ea
Assorted Waterman Aluminum Drop in Jets 3.00 Each
Standard Manifold Studs 4 $7.50
H-11 Manifold Studs 10 $15.00
H-11 Inner Head Studs Used 61 $15.00
12 Good Used 4" Inner Head Studs 10.00 Each
8 Good Used L-19 Inner Head Studs 1/2" x 3 3/8 long 17.00 each
17 Good Used 1/2 inner head studs steel 3 3/4 long 7.00 each
Misc RS2 Dechellis Stands 10 $100.00
New Hemi Head Valve Cover Gaskets Steel insert FelPro 1657 22.00 each
New SCE BAE Fat Head Valve Cover Gaskets 19.00 Each
Std Fuel Down Nozzle Fuel Rails for heads titanium 175.00 each or stainless 150.00 a set no jumpers but I do have
20 New Titanium Cluff Style Exhaust Hemi Rockers with interchangeable tips 150.00 each
13 Large Used BAE Exhaust Rocker Arms Great Shape large adjuster 150.00 each
6 New BAE Exhaust Rocker Arms large adjuster 245.00 each
2 Good used 1.6 Stage V Intake Rockers 40.00 each
4 New Stage V 1.8 Intake Rockers 75.00 each
3 Sets of Used Hedman FC Headers for AJ-5 Fuel Heads 550 a set
CLUTCH AND DRIVETRAIN:
Used AFT 3/8 Wide .125 Primary Levers 10 $80.00
100 New SSI .350 thick 4 groove 3/8 wide cutters for 8 Stand Clutch 30.00 EACH
1 Used Set Nice Alan Johnson Multi Radius Clutch Primary Levers .375/.280 200
1 Set of New Titanium Bellhousing Studs for Cannon 35.00
used JT 28P3 Multi Radius Primary Arms 1 $300.00
Jt Stewart Bearing Carriers With Throwout Bearings No Linear Flag 3 $100.00
Jt Stewart Bearing Carriers No Linear Flag 2 $40.00
Rob Moore Drive Coupler Clamps 3 $20.00
Rob Moore 4 Inch Good Used Drive Couplers 3 $100.00
Rob Moore Reverser Front Bearing 1 $15.00
Rob Moore Reverser Rear Bearing 2 $25.00
Trick Titanium 9.400 Dragster Bell housing Keyhole $2200.00
Trick Titanium 8 5/8 Dragster Bell Housing 1800.00
New Chrisman Rearend Spindle 1 $240.00
New Chrisman Old Style Drive Hubs Set 1 $180.00
Used Chrisman Pinion Housing 1 $190.00
New Chrisman Drive Coupler 1 $165.00
Box of Used Aluminum Chrisman Lug Nuts 1 $45.00
Used 1 Titanium Dragster bell housing arm 150.00
Chrisman Axle 2 $450.00
1000 Tall Green stall springs 40.00 set of 6
9 New A-1 9/16 Flywheel Studs for 5 Disc Clutch 14.00 each
Three 8 stand East/West tit clutches complete $ 3500 ea. certified
Good 1 3/4 Input Shaft 10 1/4" 175.00
Good 1 3/4 Input Shaft 9 3/4" 175.00
1 AFT Steel Clutch Fork 3 3/4" tall 85.00
CHASSIS PARTS:
Dragster 2 1/4 Aluminum Main Fuel Line Straight Tubes 6 $75.00
Murf McKinney Coated Motor Plate for Dragster Used 2 $225.00
Mageira Triple Element Spill Plates 3 $450.00
Big Tube Carbon Fiber Belly Pans 2 $1,250.00
Mageira Triple Element Rear Top Fuel Wing Current Certification 1 $6,000.00
Mageira New Style One Piece Front Wing w/ Current Tag 1 $5,700.00
New 120" 1/4" Throttle Cable 1 $85.00
Each New Clampco engine band clamps (2) 150 7.50 EACH
Large magnesium Murf McKinney CO2 Air bottle clamp 161-AM 45.00
1 Small CO2 bottle with small reg 120.00
1 McKinney Clutch bell crank for dragster M-269 25.00
Various new and used push pull cables contact me for price and length $$$$
Murf Dragster Chrisman Rearend Plates used 175.00 set
McKinney Dragster Brake Handle std dragster not 5/16 with carbon grips 70.00
Good used set of Weld Magnum Bead lock wheel centers removed to install 15.4 update 170.00 each
Good used set of Weld 16" Fuel 15.3 Double Beadlock Wheels Gold 5" BS 1000.00
Spare beadlock weld rings painted black 35.00 each
Set of current cert 15.4 Weld Beadlock wheels 5" BS 2200.00
2 McKinney tall body 15 gallon fuel dragster fuel tanks 250.00 each
1 Set of small tube McKinney Fuel Dragster chrome Moly Forward Struts 82" 350.00 set
1 Set of Lamb 1602 calipers with steel rotors and metallic used pads still good 900.00
1 Set of Lamb 1602 calipers with carbon pads .425-.450 on pad thickness 1100.00
1 New McKinney Titanium Dragster rub block 120.00
2 Sets of good used spritzer carbon fiber mudflaps 500.00
FRONT WHEEL PARTS ALL NEW
Seals
Timken 471795 6.50 each
CR/SKF Seal 14844 7.00 each
Federal Mogul 353141 5.00 each
Federal Mogul 253099 3.00 each
Races
Timken 67204 9.00 each
Timken 03162 8.00 each
Bearings
Outer Timken 03062 15.00 each
Inner Timken 07098 10.00 each
RACEPAK:
COMPLETE RACEPAK PRO II SYSTEM WITH DASH 13,000.00 will not sell dash separate
2 Racepak Pro II Download Cartridges 75.00 each
2 Good Used Racepak Analog Box PRO II 55.00
1 Good Used Racepak Analog Box Pass thru PRO II 55.00
1 Input A Module Events 175.00
1 Input B Module Timing 175.00
New Racepak 500 lb transducer ProII 180.00
Used Racepak 0-5V Out 75.00
Used Racepak Batt Voltage Transducer 75.00
Used S to Z Pos Transducer 50.00
Used Temp Transducer 75.00
Used 400 lb Transducer 125.00
Used 150 lb Transducer 125.00
Used 60 lb transducer 125.00
Used 600 lb transducer 125.00
Used 750 lb transducer 125.00
Used 1000 lb transducer 125.00
Used 200 lb transducer 125.00
Used G/M Transducer 65.00
Used 0-5 Out Transducer 70.00
36" Racepak Analog Cable 35.00 Used
37" Racepak Analog Cable 35.00 Used
13" Racepak Analog Cable 35.00 Used
49" Racepak Analog Cable 45.00 Used
52" Analog Cable 45.00 Used
60" Analog Cable 45.00 Used
89" Racepak Analog Cable 50.00 Used
15' Temp Cable New 100.00
68" Temp Cable New 70.00
14' New EGT Cable 200.00
14 1/2' Good Used EGT Cable 150.00
13' Used EGT Cable 150.00
49" New Flow Cable 75.00
51" Used Flow Cable 50.00
115" Used Flow Cable 50.00
120" Used Flow Cable 50.00
30" New 3 Pin Cable 40.00
37" New 3 Pin Cable 40.00
88" New 3 Pin Cable 50.00
5" Used 3 Pin Cable 20.00
28" Used 3 Pin Cable 45.00
32 1/2" Used 3 Pin Cable 45.00
50" Used 3 Pin Cable 45.00
90" Used 3 Pin Cable 50.00
208" Used 3 Pin Cable 65.00
62" TDC Cable Used 50.00
43" 2 Pin Power Switch Cable 40.00
Power Switch w/jumper cable 20.00
9" Pressure Transducer Jumper Cable Adapter 20.00
87" Fiber Optic Cables set of two 50.00
Good used egt boxes 75.00 each
NEW Bullet EGTS set of 8 600.00 a set
SAFTEY & RESTRAINTS:
New Simpson Black 10' Chute Bags $45.00
2 TAK Titanium forward inlet fuel blower lower restraint plate 500.00
3 Taylor Fuel Dragster Diapers great shape 500.00 each
1 Set of Valve Cover Blankets TAK needs a little repair singed outside layer on one side 250.00
1 Taylor Used Wheelie Bar Net 40.00
2 Simpson Used Wheelie Bar Nets 40.00 Each
THERE ARE FAR MORE PARTS AVAILABLE THIS WAS JUST A TASTE OF WHAT IS HERE.
Some prices are negotiable. Contact Scott Gaddy at 704-778-6974 or nitrostacker@gmail.com More can be seen at scottgaddyracing.com
nitrostacker
Re: parts and pieces for sale large list
Postby sandaltered » Tue Oct 13, 2015 2:46 pm
How about used 36" Goodyears?
I'd be in the market for about as many as you could supply.
Return to Sand Car Classifieds
